112+2, 111+1, or 110+0?
i am going to to a H/C package on the WS6 and nee some assistance on picking the lsa. here is the setup.
5.3 heads milled to 60 cc with a 2.02 intake vale and stock exhaust valve
.040 head gasket
228/232 comp XER on a ????
lets hear it.
.040 head gasket
lets hear it.
Do you allready have the heads and gaskets?
If yes then 112+1 but with stock gasket
Or if you have both, then
114+1
If no then only mill to 63cc with .040 for ~11.2 and 8.7 DCR on a 110+1 LSA (best combo IMO)
See it has to do with DCR and you do not really want it above 8.7ish
114+1
Originally Posted by No Juice
from the sticky calculator and PianoProdigy calculator I get 63cc w/.040=10.82 SCR
which one are you using? are these wrong?
You had better think about notching your pistons because of PTV danger. I've got a XER 228/230 112+2, with unmilled 5.3L heads and it didn't fit. Clearance was as I recall only about .045".
A little over 400 rwhp and 390+ rwtq. This is with a 9" rear and Denny's Nitrous steel DS. Plus I just had my Absolute Speed heads cc'd and the chambers were 69cc and intake runners 245cc. Not exactly optimum for a 346.Erik@HorsepowerEngineering.com[/email] is building a 408 for me and I'll use these heads on it to save $, definitely a compromise.
Originally Posted by PREDATOR-Z
You have to put a negative value for piston deck height -.007
