Convert to a 6 speed?
Old 12-08-2006, 08:37 PM
sabres97's Avatar
Default Convert to a 6 speed?
if i took out the 4l60e tranny and replaced it with a t56 would it resemble stock or would i have problems or should i just put in a shift kit?
Old 12-08-2006, 09:12 PM
99Hawk262's Avatar
Swap can be done without too much difficulty. And yes, if done properly, it will look like it came that way. Why don't you try a stall converter? Will very likely change your mind about the automatic.
Old 12-09-2006, 02:03 AM
sabres97's Avatar
im a newbie when it comes to trannys what would the stall converter make the car shift like?
Old 12-09-2006, 08:05 AM
Ragtop 99's Avatar
shifts might feel a little less firm. Having a Converter is like being able to dump the clutch at 3500 rpm when launching.
