removing wrist pin from piston
Old 12-09-2006, 09:35 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Default removing wrist pin from piston
Is there some tool that you have to have to do this? I am sure that it is pressed in. Anyone have a makeshift easy way to remove the wrist pin? Pistons are out of the block and I really don't care what happens to them. Just need the wrist pin out.
Old 12-09-2006, 09:52 AM
boondiggys's Avatar
maybe you just want them for christmas tree decorations?...theres no easy way...take them to a shop.
Old 12-09-2006, 10:55 AM
staringback05's Avatar
theres not a exact easy way....we used to push them out with a press....
Old 12-09-2006, 05:05 PM
TATER's Avatar
Are you gonna reuse the stock rods, or weld the pins together and make a really cool dart gun?
Old 12-09-2006, 05:16 PM
2002_Z28_Six_Speed's Avatar
Yea, just don't reuse the pistons. Try heating it and using a 1 ton shop press. That would get it out.
Old 12-10-2006, 11:18 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I just said to hell with it and pressed them out. Heat makes metal expand. Why would I do that? hahaha
Old 12-10-2006, 11:19 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
They are tooled steel $$$, so I wanted to keep them. Stock piston with eagle rod.
Old 12-12-2006, 01:03 AM
What has the motor been though? A large force could impair the max force the rod could take without visually damaging it.
