Head flow numbers???
Port Lift Corr/CFM
Int#1 .100 62.7
Int#1 .200 130.8
Int#1 .300 189.5
Int#1 .400 225.6
Int#1 .500 256.6
Int#1 .600 271.5
Ext#1 .100 49.2
Ext#1 .200 102.7
Ext#1 .300 138.0
Ext#1 .400 164.4
Ext#1 .500 187.0
Ext#1 .600 198.4
SO is this good/bad or just ok?? These are on 853s milled .015.
Int#1 .100 62.7
Int#1 .200 130.8
Int#1 .300 189.5
Int#1 .400 225.6
Int#1 .500 256.6
Int#1 .600 271.5
Ext#1 .100 49.2
Ext#1 .200 102.7
Ext#1 .300 138.0
Ext#1 .400 164.4
Ext#1 .500 187.0
Ext#1 .600 198.4
they look pretty respectable to me for 853 castings. CNC'd 243's are checking in about 25-40 more CFM. stock 243's are around 240 at .600 so you've bested them by 31 cfm.
Originally Posted by 1989GTA
You won't know until you go down the track or put the car on a dyno. There is a lot more to a good set of heads than flow numbers.
I'd rather a set of heads that flow 270cfm with ~stock sized runners than a set that flows 300 cfm with 240cc runners.
Ben T.
Also, the port work can't be to pathetic because they continue flowing all the way up to .600" lift w/o backing up.
...but midlift numbers could be a little better.
Ben T.
Ben T.
Ben T.
Ben T.
I agree with Studytime. The flow from .500 lift to .600 lift shows they are not backing up or trailing off. Just make sure you have a cam with enough lift to take advantage of the heads. More to the cam thing but that is left to others.
