Procharged guys...
Procharged guys...
Which rocker arm's are you guys going with? Preferably, i'd like to hear from anyone making over 600rwhp but all are welcome. This will be a 347/D1 combo. I was thinking of going with the Y/T's but just wanted to get some input.
Thanks in advance,
Chris
Thanks in advance,
Chris
I haven't heard good things about the Y/T's. I had some, but was getting valve float. I ended up selling them and had my stock ones rebuilt by Harland Sharp with their bearings, and they installed these C-clips so if the rocker arm fails it wont fill your engine with all those needle bearings.
If you do want aftermarket roller rockers, there are much better alternatives out there than the Yella Terras.
Senior Member
The only way the YTs will cause valve float is if the springs are already on the edge. The YT rockers are heavier on the valve tip than the stockers. The new YTs are supposed to cure this. Ive never had a problem with valve float with my YTs even when I had a nasty H/C setup.
I have rev-ed my yts to 7000 routinely with no problems. That means nothing to the people that have had problems I realize. Will use them again soon as Im running again.
