LG G5X4,Afr 205's, and compression
I am going to build my 383 stroker soon and before i buy my pistons I was wondering with a LG G5X4 cam,Afr 205's what we will be the best compression ratio for this and I also have 150 wet shot I will use some times with this combo.
Originally Posted by purdueranger
The X4 is on a 111 LSA. If you run a 59cc head with a .040 head gasket thickness and you have a 1cc valve relief per cylinder then your compression ratio is 11.45:1.
Originally Posted by PREDATOR-Z
Sorry, I goofed, I read it as X3, but with setup you stated on stock block SCR is ~11.65 (assuming piston deck height is -.007 {out})
Opps, I have been so used to everything having 0 deck for engineering or ICEs that I forgot to add that -.007 into my equations.
