Free Ram Air ??
Old 12-10-2006, 10:32 AM
bow125106's Avatar
Default Free Ram Air ??
I am about to purchase a lid and am going to be doing the free ram air mod...my question is......do i have to reset anything on the car when i do these mods....like will i have to unhook battery etc...or can i just do the free ram air, put the lid on and start up and go.......
Old 12-10-2006, 11:22 AM
SweeTbone's Avatar
Put the lid on, start up and go. You don't have to unhook the battery or anything. The PCM will "learn" as you go through mods. You can stay on a stock tune usually up until you get a cam. I'm still on a stock tune with all the mods in my sig, waiting for said cam.
Old 12-10-2006, 11:34 AM
1-Quik-LS1's Avatar
i just bolted up and went, no problems for me
Old 12-10-2006, 12:13 PM
staringback05's Avatar
i dont know if id mess with the free air mod....not much in the way of results, and it will get your filter dirty as hell
Old 12-10-2006, 12:18 PM
MrDavid's Avatar
I would definantly do it. Once you do that it will make more power for every other mod you do in the future.
Old 12-25-2006, 04:57 PM
transamhottie06's Avatar
ok when yall are talking about the free ram air mod are yall talking about cutting the bottom out of your box bc i have heard of that but didnt know if it really helped?
Old 12-25-2006, 05:03 PM
RedlineTA's Avatar
yeah they are
Old 12-25-2006, 05:12 PM
bmxer8699's Avatar
yea, this is an easy and free thing to do.. well beside buying the lid and filter.
Old 12-25-2006, 05:45 PM
So can you really tell the diff or is it not worth doing?
Old 12-25-2006, 08:57 PM
cabech984's Avatar
Can tell, the difference in a filter, or a sb? Every bit adds up, little or big, I say go for it, its a little bit less restrictive.
Old 12-25-2006, 09:26 PM
blacktransam's Avatar
the free ram air mod is great if you like HOT air and reduced power.. with that mod you actually pull your air from down infron of the radiator.. monitor your IAT's and it will scare you.. and then youll learn to just shim up the lower air box..
Mike
Old 12-26-2006, 02:26 AM
bmxer8699's Avatar
Old 12-26-2006, 08:44 AM
CJDZ24_Z28's Avatar
you have to do free ram air mod to get a SSRA,Whisper cold air scoop or FTRA. I would highly reccomend a cold air scoop not just the free ram air alone
Old 12-26-2006, 03:07 PM
Moderator
jimmyblue's Avatar
I would not do the FRA mod and didn't like what the
SLP CAI did for (to) my inlet air temps. FRA will draw
up hot air when idling / parked, heat-soak your IAT
and pull timing for several seconds after.
A good cold air setup is another matter but FRA is
not "good".
I think a lid and no chopping, but try and isolate the
nose space more from the engine compartment and
cut out as much styrofoam from behind the "nostrils"
(if it's a Camaro) as you can is a better way to go.
I hacked up my CAI to draw from above the divider
panel, via the "nostrils" and it fixed what that piece
was doing to the IAT readings. Not to mention a big
unshrouding of the radiator / trans cooler.
A non-SS hood should be looking to the nose space
for air draw, it seems like to me. Just need to make
engine compartment air stay out of it, and get more
fresh air into that space. Couple pieces of angle stock
for a heat dam, and a few minutes with a steak knife
(for the foam), good to go.
Old 12-27-2006, 09:38 PM
greysteel_M6's Avatar
i'd pass on the free ram air, dirty filter=bad
Old 12-27-2006, 10:33 PM
Marblehead's Avatar
I thought about doing FRA mod and decided that the negatives outweighed the positives.
Old 12-28-2006, 09:57 PM
WS6 Rampage's Avatar
Location: The dirty taint of the country. ...Los Angeles
Mike
See,.thats why I took a saw-zaw to my WS.6 hood. NO HOT AIR!!! lol
Old 12-29-2006, 12:29 PM
2002/ws6's Avatar
i did the free ram air mod, yea your filter is going to dirty a whole lot quicker, but i have no regrets doing it, then all you have to do is clean your filter!...does it make a difference, personally i really couldn't tell the diff.
Old 12-30-2006, 07:19 PM
CJDZ24_Z28's Avatar
Why do you guys not do the Free Ram air and add this? Guaranteed gains and fuel economy.
http://www.lmperformance.com/1858/1.html
Also check the dyno results for it here.
https://ls1tech.com/forums/dynamometer-results-comparisons/608941-02-z28-w-ptb-dynoes-298-w-slp-lid-dynoes-303-w-slp-lid-ssra2-dynoes-318-a.html
Old 01-02-2007, 07:04 AM
RoWDyWS6's Avatar
like Nike, Just Do It!
