Brake, ABS inop, TRAC off
Old 12-10-2006, 08:37 PM
underated98Z's Avatar
Default Brake, ABS inop, TRAC off
Don't know if this is the right section. My Brake, ABS, and TRAC light all comes on at one time intermediately. Some days it will not come on(usually when it is cold out side) and some times it comes on and then goes off for a while and then comes back on again. I have bleed the brakes, replaced rotors and brake pads. I really don't know what could cause this. Any of you guys may no what is causing this. Thanks
Old 12-10-2006, 09:48 PM
TX_SS's Avatar
itz the sensors... you might wanna check your rearend TCS/ABS bracket. itz coming lose or sensors are goin bad.
Old 12-10-2006, 10:07 PM
Ok will do. Thanks for the help.
Old 12-11-2006, 05:54 PM
ksuburban's Avatar
Get a code first, then go from there
Old 12-12-2006, 01:18 PM
pcgamer4life's Avatar
I have the same problem, but my lights are on constantly... never go out, never blink, always on. Where's the sensor located, and can you get a code from it if the SES light isn't on?
Old 12-12-2006, 04:20 PM
I have already scanned it for codes and none show up. But I am going to replace the sensors anyway. Hopefully that will fix the problem
