Brake, ABS INOP, TRAC off
Don't know if this is the right section. My Brake, ABS, and TRAC light all comes on at one time intermediately. Some days it will not come on(usually when it is cold out side) and some times it comes on and then goes off for a while and then comes back on again. I have bleed the brakes, replaced rotors and brake pads. I really don't know what could cause this. Any of you guys may no what is causing this. Thanks
Originally Posted by ksuburban
Just like every other light, get a code.
I am going to replace the sensors. But I already had the car scan for codes and none came up. So guess I will have to do alittle of troubleshooting to figure this one out.
