General Maintenance & Repairs - Spark plug change at every 100k?
View Full Version : Spark plug change at every 100k?
jinxeng
12-11-2006, 12:13 PM
I was going to change out my plugs, it has 35k miles on a 2000 camaro z28. The service provider at a chrevrolet said it will last til 100k miles ? They said I had platinum plugs installed. Tey said it would cost 600 bones to change it out if need be.
Is this right ? I thought I would have to change it every 30k, 60k miles and so forth. As always, thanks.
taintedmeat
12-11-2006, 01:02 PM
They are platinum plugs, but the platinum disk on the plugs is probably gone. Don't pay 600 to have them changed. Spend 30 bucks on some tools if you don't already have them; universal joints and various extensions. Buy 8 plugs for under 20 dollars, and do it yourself in a few hours.
2002_B4C
12-11-2006, 01:51 PM
word! :burn:
3.4camaro
12-11-2006, 03:43 PM
NGK-55 plugs
10MM deep socket
5/8" deep and rubbered spark plug socket
universal joint
1", 3", and 10" extension
and you saved $500. go you! :)
2001NBMZ28
12-11-2006, 04:01 PM
$600? Advisor must be getting $10 from a service tech every time he says that, so he won't have to change any. :jest:
staringback05
12-11-2006, 04:11 PM
:lol: even my guy who does my major work said he only charges like 200.....certain types of plugs wil last about that long, if your not putting alot of hard runs on them
RPM WS6
12-11-2006, 08:24 PM
I would hate to be the guy that has to pull 100k mile plugs out of an aluminum head.
I'd change 'em. And forget the $600. That's nuts.
jinxeng
12-12-2006, 12:48 AM
thanks for the post bros
98ws61le
12-12-2006, 09:11 AM
600 bucks...... that is crazy..... i like the.....
acdelco 41-985 PRESET GAP .040
Double Swivel Spark Plug Socket 5/8"
offset flex head 3/8 ratchet
if you have the extra cash change all the fluids out too even with that no where near 600 bucks...he should be burned at the stake
take a read at http://www.installuniversity.com/install_university/installu_pages/freshman_year/spark_plug_and_wire.htm
lo_jack
12-12-2006, 09:46 AM
Spark plug gaps change slighlty over time under normal operation. I would not let them go 100k without at least pulling them and checking the gap at 50 or maybe every 30k.
RyanZR1SS
12-12-2006, 10:45 AM
It took me and ONE BUDDY to do it in 45minutes. Notice I said one buddy and 45 minutes for all 8 with wires.
00formLs1
12-12-2006, 10:57 AM
it takes me about 45min to an hour with my Lt's. i am running tr6 so i change mine every 12-15k
ws6togo
12-12-2006, 11:00 AM
NGK-55 plugs
10MM deep socket
universal joint
DIY and save lots of $$.....as cheap as they are I change mine every year. Changing them every year I wont even spend $600 total
taintedmeat
12-12-2006, 12:11 PM
It's worth it to change them even when they don't "need it". It's a lot better than driving on them until one fouls on you, and then having to drive on 7 cylinders until you can get around to changing them. :judge: :drive:
staringback05
12-12-2006, 05:01 PM
just make sure youve got alot of patient if you do them yourself
00formLs1
12-13-2006, 01:17 AM
i could never imagine how hard it would be on stock manifolds.
taintedmeat
12-13-2006, 07:59 AM
It's actually not all that bad. With the air tubes out of the way and a couple of coil packs moved on the pass side it's cake.
