Suburban roof console in a ta?
has anyone put a roof console out of a suburban in a camaro or trans am? like between the ttops part? i think itd be awesome to relocate the air conditioning up there and use the space for a custom nav unit. just a thought. My moms got a 99 suburban and it doesnt look like the stock air control unit will fit in but it may i dont really know. What does the roof console look like in the next generation after my moms? Anyone ever done this? any imput guys?
Considering that you'd need to extend a vacuum line as well as a couple of cables, not including electrical lines I'll let you try this out first. I've thought about this before too as well as a few others, but I've never seen anyone actually try it out. Most people just relocate the HVAC to the glove box.
ive had thoughts about doing something like that or relocating it somewhere because i want to put a double din unit or car pc in that area, just dont know what exactly is needed to relocate
yeah def knight rider...they have kits for that...im not sure where...but im sure if you searched knight rider roof console you may find soemthing..therre was a post about this kinda thing not to long ago. the kit looks like a friggin spaceship...but hey...its a kit for that...im sure you could customize the look a little. good luck, and keep us updated
I swapped the roof lining on my old F-body awhile back. There isn't room to run more than small *** wires and I doubt you would enjoy mounting anything to the thin *** roof.
I would say nothing more than a panel with all of your nitrous switchs should go there. They would stiff hang down to much and I don't believe they would be mounted firmly.
I swapped the roof lining on my old F-body awhile back. There isn't room to run more than small *** wires and I doubt you would enjoy mounting anything to the thin *** roof.....
http://www.decorp.com/
I was looking to do something similar, but with guages instead. I know the turbo buick guys have t-top pods for gauges, and newer trucks have roof gauge pods. You could always build your own box to hold the hvac unit up.
