Drag Racing Tech
Ever broke a stock 10 bolt w/ stock stall and sticky tires?
Old 12-12-2006, 12:46 PM
Bitemark46's Avatar
Default Ever broke a stock 10 bolt w/ stock stall and sticky tires?
I was gonna throw some ET Streets on the wifes car to see what it does. But from watching videos of M6's cars on here and doing searches for 9" and 12 bolts I'm starting to get gun shy about doing it. Her car doesn't make much power 300-310rwhp. Am I risking it? Thanks. -Mark
EDIT: it has 3.42's
Old 12-12-2006, 01:31 PM
fastenough's Avatar
She'd prolly be fine if its stock still but don't go launching the **** out of it.
Old 12-12-2006, 02:00 PM
LilSlo1's Avatar
10 bolts behind a A4 usually last a little longer. I 've got a whole season on mine, and still have no problems. When the car was stock with a set of ET Streets it slowed the car down. I did put a girdle on the rear end to give it somewhat a chance of living. See mods in my sig for the Trans Am.
When I leave off idle the car will 60 foot mid 1.70's
Stalling it up as high as it will go (about 3400 rpms) 60 foot is high 1.60's to low 1.70's.
60 foot times
Four high 1.60's
Dozen low 1.70's
Too many to count 1.80's and slower
And still no noises or problems yet.
Old 12-12-2006, 02:56 PM
Magnet's Avatar
with the stock stall your not hitting the rear hard enough to break it IMO i have had many passes on nittos dead hookiff the line with stock stall and no noises or anything
Old 12-12-2006, 03:05 PM
Bitemark46's Avatar
So a rear girdle huh? I'll have to pick up one. Don't know where to shop for bargain prices for the LS1... any good places?
Crawlin- you said you slowed down? Can you explain? Thanks. -Mark
Old 12-12-2006, 03:39 PM
FloydSummerOf68's Avatar
My 10 bolt has seen numerous 1.7s and now is taking high 1.6 60s.
I'm going to put a rear girdle on as well to try and help the life. Thunder racing has a decent price on them, and I think PFYC carries an SLP girdle.
Old 12-12-2006, 07:02 PM
Vintage Iron55's Avatar
My Brother put a season on the 17 spline dropout 10 bolt in his 56 Chevy with Et Streets with 3800 stall. Those are notoriously weak under abuse, but he has not broken his. I broke the snot out of that type of rear end with my manual transmission, but the auto doesnt seem to be so hard on them. From my experience, the results of slicks on a stock car with a stock converter seem to be a bog off the line. Be sure NOT to use tires with a larger diameter than stock or the condition will worsen. This is due to taller tires having the effect of reducing the gear ratio. Go wider instead if anything.
Should be fun.
Henry
Old 12-12-2006, 07:03 PM
SiL3NtXWS6's Avatar
my friend broke 2 10 bolts on the street with street tires at 350whp... it's hit or miss
Old 12-12-2006, 08:00 PM
gator's 99TA's Avatar
mark you saw andy run 10.40s this weekend at BMP with a stock 10 bolt with 3.73 gears (weaker than stock). his best was 1.44 60'
i wouldnt worry about it too much. et streets will slow down a stock stall car.
Old 12-12-2006, 09:40 PM
Retired Street Racer
Matt D's Avatar
I ran numerous 1.4X 60fts on a stock 10 bolt, 3.42s, & slicks with a 4600 stall. Stock stall won't hit as hard, so you have nothing to worry about.
Old 12-12-2006, 11:15 PM
Bitemark46's Avatar
How? If it's the same OD how can it slow it down but a MT DR doesn't? I'm cornfused. -Mark
Old 12-12-2006, 11:50 PM
Magnet's Avatar
you get too much traction, go with nittos
Old 12-13-2006, 12:08 AM
daniel6718's Avatar
i been 1.5x as long as it has stock gears its alomst indestructable with d/r...coulple guys areound here with 3.23 and 3.42 cars are doing low 1.4x, most people you hear about breaking them either have gears, or are dumping the clutch with too much clack in the drivetrain...
Old 12-13-2006, 01:57 AM
Taubr Unit's Avatar
girdle that bad boy!! My buddy has a '02 TA on a 10 bolt with a girdle also. Launched it and broke a axle but everything was still held toghter with the girdle, gears were still perfect (4.10's). I think with moser axles and a girdle and a 10 bolt should hold up pretty good with a auto.
Old 12-13-2006, 01:44 PM
LilSlo1's Avatar
When my car was bone stock, it went faster on a street tire. The slicks actually slowed the car down. I guess mabey a little wheel spin at the tree might have acted like a small converter, compared to dead hooking with the slicks. It actually sounded like the slicks were bogging it down, but don't get me wrong the slicks kept the car consistant when it was stock.
But now street tires are not even a choice for the track since I put the converter and exhaust in.
Thats why i am leaving the stock 3.23 in my car. When and if the rear end breaks it will be time for a 12 bolt. I just put a girdle on it to give it a little chance, and mabey if I get 250 bucks burning a hole in my pocket I'll slide some axles in it....Yes I know its a waste of money.
Old 12-13-2006, 07:00 PM
Does anyone know how much a girdle actually improves strength?
I dont know if there are any numbers out that would have a percentage increase in strength over stock...but if there are I would LOVE to see them.
And what about the TA girdle over the SLP girdle? I think SLP is cheaper....strength differences?
Old 12-13-2006, 07:13 PM
smokeum99ta's Avatar
EDIT: it has 3.42's
I hate to be one to tell you but 10 bolt's ain't very strong. I've broke at the least a dozen 10 bolt's between two different cars (1 m6 & 1 a4). They would seem to survive until I put any kind of sticky tire on them. And this was when I was making under 400rwhp. But I have to admit I would launch hard every time just waiting to be trailered home.
Old 12-15-2006, 07:03 PM
Matt D's Avatar
I launched off a foot brake at 4000rpms on a full slick for two seasons on a 10 bolt. Never had a problem. But then again, my car only ran 10s...
Old 12-15-2006, 11:10 PM
Bitemark46, to answer your question, the street tires with the same OD will spin and give you artificially lower "feeling" rear gears and allow your engine to turn rpm where it actually makes more torque, but wheelspin is seldome consistant. When you put hard gripping slicks on a stock car without a good converter the bogging effect is really that since the tires will not spin, you lug the engine at an rpm where it makes less torque and has less inertia. That is why people with the slicks use a looser converter and lower rear gears to allow the engine to hit the rpms where it makes good power. I know it sounds a little hard to beleive at first, but it's true if you think about it. Guys with manual transmissions will actually want the slicks to spin 1 to 1 1/2 rotation on launch for this reason. In a locked up drivetrain, something has to slip for the first 30 feet or so. Tires, clutch, both...
Old 12-15-2006, 11:56 PM
JUICED96Z
Guest
Posts: n/a
I have a low mile 10 bolt with 4.10's, stall, engine work, built tranny, suspension, bottle, ect ect, 28 inch tall 15X8 E.T. street. I am not worried about it but don't plan on launching hard lol
Quick Reply: Ever broke a stock 10 bolt w/ stock stall and sticky tires?
