ground clearance?
ground clearance?
What kind of ground clearance can you excpect with pacesetter LT's? if anyone could post up pics of clearance that would be really cool. thanks in advance
That's what she said...
Originally Posted by BIG_MIKE2005
You'll be fine on the LT's clearance. Its the 3" ORY that makes you lose some.
The pacesetters fit great. The pacesetter y-pipe will probably give you the most clearance of all of them. It has a crushed section, which allows it to ride a bit away from the floor pan without giving up ground clearance, doesn't rob any power though.
