'00 LS1 throttle screw location???
Kleeborp the Moderator™
Originally Posted by TheBlurLS1
Look at the closed position throttle body stop, where the rotating piece rests when it's closed. This piece lands on the screw, you can adjust it from the bottom, but might have to take the TB off.
Moderator
If you screw with the screw you may have to do a
TPS relearn to get idle TPS% right (back to 0%).
Wonder why people don't drill a pair of holes and
put an idle air bleed screw like carbs. Looked at
that way back, seemed doable, but with tuning tools
there's no need to make shavings.
