is a swap to a .040 gasket thae same as a .015 mill?
Old 12-12-2006, 05:52 PM
ls2 bait's Avatar
Default is a swap to a .040 gasket thae same as a .015 mill?
because the stock gaskets are .056 right? so would this be similar bump in compression or no because of the contours of the cc chambers?
Old 12-12-2006, 06:26 PM
GuitsBoy's Avatar
Its similar but not exact. every thou off the head reduces the chamber less than off the gasket because of the quench pad. For a stock LS1, every .0050 off the gasket = 1cc, every .0065 off the head = 1cc. Reducing the gasket tightens the quench which is good for power and knock prevention, however it brings the picton closer to hitting the head.
Old 12-12-2006, 06:36 PM
cws T/A's Avatar
raises the compression comparable to a 64-65cc 10.50:1. tighter quench to help fight off detonation , win/win situation .
Old 12-12-2006, 07:40 PM
allngn_c5's Avatar
Looking fwd to see how my car responds to using .040 headgaskets. The current gm performance mls .056 failed.
Old 12-13-2006, 08:59 AM
ls2 bait's Avatar
id really like to run a .040 gasket but i dont think it will work with the prc 2.5 5.3's im looking at without flycutting. im just trying to figure out what to do. thanks for your replys
