Are all the LT throttle bodys the same on TAs?
Old 12-12-2006, 07:27 PM
mvvette97's Avatar
Default Are all the LT throttle bodys the same on TAs?
I was thinking that somebody said the 93-94 was differant than the 95-97. is this true?
Old 12-12-2006, 07:48 PM
Formula_LT1's Avatar
I think the throttle body itself is the same, but the coolant routing is different.
I don't know if you've ever heard anyone talk about the "throttle body bypass mod" or not, but I would say if you resarched that, you probly get a more deffinant answer.
Old 12-12-2006, 07:52 PM
mvvette97's Avatar
Yea I have heard about that. I wonder if I didn't use the coolant lines if they would all work?
Old 12-12-2006, 11:47 PM
the_merv's Avatar
As long as the line from the Heads gets to the Radiator, you are good.
Quick Reply: Are all the LT throttle bodys the same on TAs?
