Z06 rims
Old 12-12-2006, 08:25 PM
pro2low's Avatar
Default Z06 rims
anybody know who makes them in an offset that will fit a 315 on my car without have to beat the wheel wells or any thing else?
Old 12-12-2006, 08:28 PM
pro2low's Avatar
i found a 18x10.5 +53mm offset from LM Performance.......would those fit?
Old 12-12-2006, 08:59 PM
Rebob5's Avatar
I have a set of 18x10.5 ZO6's still in the boxes and from the research I did most people say that 53mm is a real good offset for f-bodys. I have been looking for tires and havent come across alot of 315's I have found alot of 295's for decent prices.
Old 12-12-2006, 09:06 PM
pro2low's Avatar
have you looked at nittos? they arent as wide as other 315's and they have a decent price dont know offhand but they also dont last too long at all. i want to find somebodys that has Z06 with 315 see what they had to do
Old 12-14-2006, 03:53 PM
pro2low's Avatar
ttt..............
Old 12-14-2006, 06:36 PM
slow94GT's Avatar
dont know if you can fit a 315, havent really heard anyone being able to. I know with a 53 mm you can definitely fit a 295 nitto though.
Old 12-14-2006, 07:17 PM
pro2low's Avatar
i will beat my fender walls a little but i dont want to do the bump stop mod and all that stuff. i need to find more people with Z06 rims!!!!!!
Old 12-14-2006, 08:04 PM
nimr0d's Avatar
I have z06, but 295/35/18 rear...dont think Ive seen/talked to anyone w/anything bigger than 295's on an 18.
Old 12-14-2006, 09:02 PM
pro2low's Avatar
do you have a 53mm offset with any clearance problems nimrod?
Old 12-15-2006, 08:56 AM
Xsta Z 28's Avatar
53 mm offset is the best availalbe offset to fit Z06 wheel in a 10.5" width on a F-Car.
Old 12-15-2006, 09:28 AM
red87iroc's Avatar
I just installed 10.5" Y2K wheels with 58mm offset on my 94 TA. They fit fine, no rubbing. But I may need to use either the BFH mod or install 1/8" spacers when I lower my car over the winter. I am hoping I can just center things with the adjustable PHB.
The 5mm difference between 53's and 58's only equals about .1968", or between 3/16" and 13/64". So a 3/16" spacer would make the offset almost the same as a 53mm wheel.
Xsta is right, 53mm is probably the best offset, but I think I would hit the lip of the wheelwell on my car if I used 53"s.
Old 12-16-2006, 03:09 AM
I8UCANNIBAL's Avatar
Default 315's PZeros,10.5",58mm,H&R 25mm
Heres the specs on my current setup:
2002 SS SLP A4
Topline C5 Z06 Chrome
18" x 9.5" Front & Pirelli PZero 275-35-18
18" x 10.5" Rear 58mm offset & Pirelli PZero 315-30-18
H&R - 25mm(~1") hubcentric spacer 5:120.65/70.5
10xDRM nuts- 125001
10xDRM bolts- 1253044
Fenders Have been rolled
No BFH mod
Eibach Sportline Springs
Koni Single Adjustables S&S- All 4 corners
Umi Adjustable Panhard Rod
Umi Weld-Subframes
Pros VS Cons opinion
Pro's- Best tires Ive had, Great traction (way overpriced though)
Con's- I dont like the way the spacers look, Front is too tucked and rear sticks out too much, should have at least went with a thinner spacer.
Overall I sought local help and guidance of local shops in marin which was not the best idea, I think the set up looks ok but would do it differently If I had to choose again.
Looking for suggestions on the following:
Would a BFH mod allow me to remove the spacer? If not would moving to a 295 or 285 be done without a spacer?
My front end camber needs to be adjusted every few months- after a fix they remain upright like they should but slowly creep inward (quite annoying and costly to fix every time)??
