PCM Shift Light
PCM Shift Light
has anyone used the HP Tuners shift light on there F-cars?? From what I understand you set up the shift Parameters in your Software and use Pin 47 on the red Connector attached to the PCM. I have not had any luck with getting an open circuit from pin #47. It stays made all of the time. any help is appreciated
