Changing Rod bolts
Changing Rod bolts
What is the easiest way to change the rod bolts out on a automatic car? Do i have to remove the tranny? or should i just drop the hole front suspension? Any advice is helpful in that im going to do this in the next few weeks and am weary about how to do it....
the correct way is to pull the engine completely out and have the engine torn down, then have the rods re-sized/honed with the new rod bolts
the rods were sized with hthe stock bolts and will distort differently with aftermarket bolts
Here's a read for you;
https://ls1tech.com/forums/generation-iii-internal-engine/618909-you-spin-rod-bearing-rod-bolts.html
Ben T.
Ben T.
