Cadillac CTS-V - leaking anti freeze
socalbro
12-13-2006, 04:01 PM
i just test drove a cts v 05 and when i pulled up at the dealership it was leaking a little antifreeze but i checked the hoses and they were not leaking soo i looked under the car and it appeared to be leaking from behind the motor??? any know what it could be i still wanna buy this car if its a small fixx but they will be repairing before i buy it.
Check out www.cadillacfaq.com do a search for radiator in the TSB (Technical Service Bulletin) section. This is a common problem, not sure about behind the motor but it could just be running back or be blow back from driving. If you can have a GM dealer run a warranty report on the car to see what all it has had done.
98redM6
12-13-2006, 04:24 PM
At what dealership? I'm in the hunt for a cts-v and I'm going down to SoCal. Just want to make sure I know about this problem and don't run into the exact same car if you don't buy it.
socalbro
12-13-2006, 04:30 PM
i cant open the pdf documents on that page
zipdog
12-13-2006, 06:31 PM
The radiators leak, it's a known warranty issue.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
