Effect of Swapping 1.8 to 1.7 Roller Rockers?
Old 12-13-2006, 07:21 PM
chipenstein's Avatar
Default Effect of Swapping 1.8 to 1.7 Roller Rockers?
Is there a formula of the effect of down-sizing from 1.8 to 1.7 roller rockers? Like how much would duration and lift be reduced, ie. the valves wouldn't open as much or as long. Shouldn't this change move the torque curve down lower in the rpm range or do I just not understand the effect of taller rockers on an engine?
Old 12-14-2006, 05:06 AM
vettenuts's Avatar
Somewhat depends on the rockers. I moved from Crane 1.8's to Crane 1.7's. Both come off the seat fast and at a higher ratio per the Crane design. I feel I lost about 6-7 hp with this move, but I am only guessing as I did it at the same time I put in my Dart heads so there was no measurement of the rocker only change. I did notice the cam sounded less "lopey" after I made this change. Valve timing won't change, only the duration at a specific lift point.
Old 12-14-2006, 10:33 AM
RZRSEDGE's Avatar
Yeah, in general instead of multiplying the actual lobe lift by 1.8 times (ex. .400 lobe lift x 1.8 ratio = .720 lift to the valve), you get a multiplication of 1.7 (ex. .400 lobe lift x 1.7 ratio = .680 lift to the valve). Duration should be similarly affected. Hope this helps.
Old 12-14-2006, 12:53 PM
Yeah, it does. I'm just trying to move my powerband down the rpm range some, but sounds like I'd be better off just sticking a different cam in there.
Old 12-14-2006, 01:10 PM
N4cer's Avatar
Effect on duration isn't as dramatic as the effect on lift, but I'm not sure how to calculate that.
