About to buy some AS 5.3 heads ... is this what I need?
Old 12-14-2006, 09:45 AM
nomorews6's Avatar
Default About to buy some AS 5.3 heads ... is this what I need?
I have a TR224 cam and am looking at this: Absolute speed 5.3 stage 2.5 heads. The numbers are 2.055 and 1.60
Is this going to be a good head to go with? How comparable are they with the PRC's ?
I would like to get up over 400rwhp with all the bolt ons including a FAST 90/90 setup.
Old 12-14-2006, 10:57 AM
nomorews6's Avatar
i was also wondering if these heads are too big or something for what i want to do, or are they going to work great?
Old 12-14-2006, 11:20 AM
PREDATOR-Z's Avatar
AS went under a long time ago. If you are buying used, with todays budget prices, PRC or PP 243 LS2 casting is the way to go.
Old 12-14-2006, 11:26 AM
slt200mph's Avatar
AS heads are old so to speak..not around anymore...TEA makes good 5.3 heads in different stages with very good flow numbers...TSP and PP makes good economical performance heads now days too using the 243 castings (LS6\LS2) I would consider one of those before using the AS heads unless you just got a some sort unreal deal for them ...
Old 12-14-2006, 11:29 AM
nomorews6's Avatar
do you all know the flow #'s for such heads? I am getting them for a few hundred less than new PRC 2.5's
Old 12-14-2006, 11:34 AM
PREDATOR-Z's Avatar
Unless they are about $400.00, I wouldn't bother.
Used heads means refresh in order:
New springs
Check all components
Decking
and who knows what is hiding???
Old 12-14-2006, 11:48 AM
nomorews6's Avatar
ok so in order to stay away from refreshening, the way to go is just buy the heads new?
Old 12-14-2006, 12:23 PM
PREDATOR-Z's Avatar
Look at PRC and PP best bang for buck.
Old 12-14-2006, 12:27 PM
slt200mph's Avatar
Well said sir..
Old 12-14-2006, 01:15 PM
N4cer's Avatar
I had a similar set of AS heads. They were great, and the dyno sheet for them is in my sig. That was my same setup, only the headers were Hedman stepped, and the cam was a 224/224 .581/.581 112 Comp Cam.
Here's the flow numbers for the heads I had:
Flow #'s,
Lift---Intake---Exhaust
.200---144------117
.300---204------157
.400---236------194
.450---277------209
.500---293------218
.550---304------222
.600---306------224
I set out to make 400hp, and made 405. So that was fine. The reason I didn't keep them is that you just can't fit a decent sized cam under them because of the big intake valves. I was below recommended clearance with the 224 cam I had. So more duration would've had PTV contact. I would say if you get them, definitely flycut for the big valves. They'd be great heads on a built motor with -4cc valve reliefs.
Old 12-14-2006, 01:18 PM
N4cer's Avatar
You're leaving out Livernois heads. Their performance per dollar is above PP and on par with PRC. And cost is about the same. Cheaper for stage 1's.
Old 12-14-2006, 01:24 PM
KingSS's Avatar
PRC all the way, $1199 assembled with dual valvesprings is a pretty unbeatable deal if you ask me.
Old 12-14-2006, 04:23 PM
bjamick's Avatar
I have seen some wicked numbers coming from the PRC heads from TSP.
Old 12-14-2006, 09:39 PM
JRracing's Avatar
Originally Posted by slt200mph
Well said sir..
+2 for me.
Old 12-14-2006, 11:12 PM
99blancoSS's Avatar
Best bang for the buck are TSP/PRC stage 2.5 5.3 ltre heads
