Trex vs 244/248 stroker cam
Old 12-14-2006, 11:45 AM
c5_ls1_6spd's Avatar
Default Trex vs 244/248 stroker cam
specs: Thunder Racing TRx V.2 - 242/248 .608/.612 110lsa +2
Stroker Cam: 244/248 612/618 on 112
Why is it that a trex can fit in stock ls6 head with no milling,flycutting, stock gaskets, and small 2.00/1.5 valves, but the stroker cam can't. does the extra 2 degrees in duration really make that big of a difference?
Old 12-14-2006, 11:49 AM
SSpdDmon's Avatar
Do the lobes have the same ramp rate? Why not run a 110, drop the duration a little, and run a little more lift?
I was thinking of this thread BTW...
https://ls1tech.com/forums/showthrea...ghlight=torque
Old 12-14-2006, 01:11 PM
i currently have the MS3 and i'm thinking of going with the 244/248 or the trex in my 346ci.
Old 12-14-2006, 08:30 PM
camarokid94's Avatar
mand those are big for a 346 those are the same specs comp told me when i called them for my 402 242-248 .610-.615 114+4
Quick Reply: Trex vs 244/248 stroker cam
