U-Joints going bad?
Old 12-14-2006, 02:20 PM
mikes98z's Avatar
Default U-Joints going bad?
Hey guys,
I am noticing one of those mysterious "clunking" sounds from the drivetrain. I can't pinpoint it but it seems to happen when the car downshifts from 3-2-1 and can be really noticeable from 2-1 when I am going real slow.
This is an A4 in a 97 T/A. I just serviced the rear about 3 months ago and it looked great. No noise coming from it or the trans.
Its annoying and seems to be getting a little worse now. Maybe the driveshaft. The trans needs to be serviced ASAP anyway.
Car has 135K miles on it...only thing I replaced was the motor mount as I tore it up on a launch one day. Replaced it with an ES piece and no problems.
Anyone have similar happenings?
Thanks in advance
Old 12-14-2006, 07:12 PM
Vicious.'s Avatar
Mine does the same thing but I have no idea why. So I'll just lurk here until someone who knows what the problem is can offer insight. Sorry I can't be of help.
Old 12-14-2006, 07:54 PM
taintedmeat's Avatar
Check out your trans mount and torque arm mount.
Old 12-14-2006, 09:19 PM
mikes98z's Avatar
replaced each of these already and torqed everything done real good...no change in what is going on with my car.
619SS's Avatar
ya check the torque arm mounts near the back mine did the same
Old 12-14-2006, 09:22 PM
mikes98z's Avatar
I didnt think to check where it mounts to the rear...I will check it out this weekend and see if that helps. If not, I will post back up and back to the drawing board.
Thanks guys...
Old 12-22-2006, 04:07 PM
JerseyLS1TA's Avatar
I know this is an older thread but i have the same question/problem. Where exactly is the trans mount and torque arm mount located?
Old 12-22-2006, 05:27 PM
Ralls's Avatar
My loose converter solved the problem with the clunk in downshift 2-1. I am also getting other clunks. Except my problem is a little different. I get a really bad clunk when shifting 2-3 or downshifting 3-2. I found a thread on it with about 10 people complaining about it, but no one ever found the problem. This started happening as soon as I installed my UMI crossmember mounted torque arm.
Trans mount is between the transmission and the crossmember. Not the crossmember for the exhaust though. Torque arm mount (clamshell) is at the tail of the transmission.
Old 12-22-2006, 05:54 PM
SuIcIdAlPoNtIaC's Avatar
you can tell if the u-joints are out by grabbing the drive shaft and seeing if it has any play in it.
Old 01-10-2007, 04:29 PM
gun5l1ng3r's Avatar
Where should we look next if there is no play in the driveshaft?^
