Which oil are you using now?
Anyone switch to Amsoil 5w-40 and have good luck? Do you all use a lighter oil in the winter? What brands and weight are you all using now?
I'm using Mobil 1 5w30 right now but I'm not sure what I'll be using next round since Mobil 1 has been found to not be fully synthetic anymore. Amsoil, RP and the like are all to expensive for my tastes. I know you don't have to change the oil every 3k like you do conventional oil but spending $50 on just oil for a change is a bit steep to me.
Internet Mechanic
I use 5-30 Mobile Clean 5000, Ill plan on changing every 2.5k-3k miles with a AC delco filter, but I my jump up to the NAPA gold truck filter used on the 6.0L motors. Dino oil was used since the car came off the show room #5 and #7 plug are the cleanest of any LS1 ive seen and the motor had minimal cold piston slap, its bearly audible.
Originally Posted by chevygirl
What about amsoil 10w-30? Anyone try it. SpaZMan what do you mean the car would burn off during start? Oil pressures with 10w-30 Amsoil, anyone?
It smoked during startup, meaning it was burning oil during start. only for about 5-10 seconds though
LS1Tech Administrator
Received 1,492 Likes
M1 0W40 with M1 filter. Works great.
