General Maintenance & Repairs - start up Noise.....
RoWDyWS6
12-14-2006, 08:56 PM
ok everytime i start my car up in the morning it makes a high pitch screechin noise...i startd noticeing it after the TB Bypass but i know that cant be it ... the hose doesnt come in contact with the pulley. After like 2-5 minutes it will just go away, i just think its really annoying...any comments??
2001NBMZ28
12-14-2006, 09:41 PM
Air pump going south maybe? Second guess would be a tensioner.
Kalgorn
12-14-2006, 09:54 PM
Does it sound like it could be the drive belt? Have you tried popping the hood after you start it up to pinpoint the sound? That would really help.
RoWDyWS6
12-15-2006, 02:13 AM
it sounds like it could be a belt. It only happens in the morning lately cause its been pretty cold down here...
staringback05
12-15-2006, 06:11 AM
belt....cold does something to them....
tattooZ
12-15-2006, 07:13 AM
Make sure the clamps are tight on the TB Bypass cause it is routed directly over the belt and pulleys. Maybe slight static leak that is saturating while the car is sitting. Its a thought...
common cause is the tensioner. do a search for more details.
BlackScreaminMachine
12-15-2006, 01:47 PM
Sounds like coolant got on the best, it could be glazed, or just stretched out and worn.
LilSlo1
12-15-2006, 02:09 PM
Take the belt off the crank pully, start it up and see if the noise is still there.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
