Staff Vehicles Showcase - LawmanSS - 2001 Camaro SS #4700
View Full Version : LawmanSS - 2001 Camaro SS #4700
LawmanSS
12-14-2006, 11:53 PM
1. Project Sponsors
None.
2. Vehicle year, make, model, mileage
2001 Chevrolet Camaro SS, 6000 miles.
3. Current Modifications List
PERFORMANCE MODIFICATIONS:
· MTI STAGE IIR LS6 HEADS
· RAPID MOTORSPORTS DOMINATOR C1 CUSTOM GROUND CAMSHAFT
· CRANE CAMS HYDRAULIC ROLLER LIFTERS
· TRICK FLOW HARDENED CHROME MOLY 7.200 PUSHRODS
· CRANE CAMS GOLD RACE ROLLER ROCKER ARMS, 1.8 RATIO
· SLP PERFORMANCE PARTS HEAVY DUTY OIL PUMP
· SLP PERFORMANCE PARTS DOUBLE ROLLER TIMING CHAIN
· ARP HEAD STUDS, CAM BOLTS, CAM RETAINER PLATE BOLT
· LS6 PCV CONVERSION
· ACCURATE MACHINE WORKS PCV CATCH CAN
· MTI/ASP UNDERDRIVE CRANKSHAFT PULLEY
· RAPID MOTORSPORTS SETUP/CUSTOM TUNING
· EVANS HIGH-FLOW WATERPUMP, CERAMIC COATED
· EVANS HIGH-FLOW 160 THERMOSTAT
· KOOKS LONG TUBE HEADERS, 1 3/4” PRIMARIES, STAINLESS STEEL, CERAMIC COATED BY JET HOT
· KOOKS 3" OFF-ROAD Y-PIPE
· BORLA XR-1 RACE MUFFLER (INTERMEDIATE PIPE)
· GMMG, INC. CHAMBERED EXHAUST SYSTEM
· SLP/OEM CENTER MOUNT EXHAUST CONVERSION
· SLP PERFORMANCE PARTS SUPPLEMENTAL COLD AIR INDUCTION KIT
· TEXAS SPEED & PERFORMANCE HIGH-FLOW AIR BOX LID
· SLP PERFORMANCE PARTS 85MM MASS AIR FLOW SENSOR
· SLP PERFORMANCE PARTS AIR INTAKE BELLOWS
· HOLLEY POWERSHOT HIGH-FLOW AIR FILTER
· F.A.S.T. LSX 90MM INTAKE MANIFOLD, PORTED/PORT-MATCHED BY RAPID MOTORSPORTS
· NICK WILLIAMS C.N.C. BILLET 90MM THROTTLE BODY
· NASTY PERFORMANCE BILLET FUEL RAILS
· RACETRONIX HIGH-PERFORMANCE FUEL PUMP SYSTEM
· KATECH BILLET BELT TENSIONER
· TAYLOR THUNDERVOLT 10.4MM IGNITION WIRES
· THUNDER RACING COIL PACK RELOCATION KIT
· A.I.R. SYSTEM DELETE
SUSPENSION/DRIVETRAIN/OTHER MODIFICATIONS:
· SLP PERFORMANCE PARTS SUBFRAME CONNECTORS
· LG MOTORSPORTS DRIVESHAFT LOOP
· PPO RACING STRUT TOWER BRACE
· BMR CHROME MOLY ADJUSTABLE PANHARD BAR
· G2 ADJUSTABLE LOWER CONTROL ARMS
· LINGENFELTER ENGINEERING 3.5” HEAVY DUTY ALUMINUM DRIVESHAFT
· SLP PERFORMANCE PARTS SKIP-SHIFT ELIMININATOR
· PRO-5.0 POWER TOWER SHORT-THROW SHIFTER W/ UMI PERFORMANCE SHORT STICK
· HARLAN SHIFT LIGHT
· SULLIVAN RACING PRODUCTS ALUMINUM PEDALS
· GRANATELLI MOTORSPORTS 200MPH SPEEDOMETER CONVERSION, WHITE GAUGE FACES
· CUSTOM EMBROIDERED HEADRESTS
· POLISHED BILLET BELT TENSIONER PULLEY
· SPEED, INC. CUSTOM FIBERGLASS PCM COVER
· GENIII PERFORMANCE BILLET ALUMINUM VALVE COVERS, CHROMED
· STAINLESS STEEL ENGINE BOLT KIT BY TOTALLY STAINLESS
· CUSTOM STAINLESS STEEL MESH GRILLE INSERTS
· S.S. INSERTS REAR CAMARO LETTER FILL-INS
· S.S. INSERTS 8" ANTENNA
· VETTEWORKS CHROME FIRE EXTINGUISHER
· AMERICAN RACING TORQ-THRUST II WHEELS: 17x9.5 FRONT, 17x11 REAR
· BFGOODRICH g-FORCE T/A KD TIRES: 275/40 FRONT, 315/35 REAR
4. Planned Modifications List
· SYNISTER MOTORSPORTS BILLET ALUMINUM POWER STEERING PULLEY
· TRACKBIRD ENGINEERING ADJUSTABLE PANHARD BAR
· YANK TORQUE ARM RELOCATION/TRANSMISSION CROSSMEMBER
· LG MOTORSPORTS LOWER CONTROL ARM RELOCATION BRACKETS
· K&N FIPKII AIR INDUCTION KIT
· C5 FRONT BRAKE CONVERSION
· LASER CUT POLISHED STAINLESS "SS" EMBLEMS
· GROUND CONTROL COIL-OVER SPRINGS
· STRANO PARTS HOLLOW SWAY BAR SET
· SPOHN CHROMOLY ADJUSTABLE TORQUE ARM
5. Current HP/TQ
451 RWHP/396RWTQ
6. Planned HP/TQ
No further power mods planned...for now.
7. Short paragraph about the car, maybe the history of it, goals, etc...
Coming soon.
8. Photos!
Here are some crappy pics:
http://www.fquick.com/images/vehicles/full/1079969356.jpg (http://www.fquick.com/garages/viewgallery.php?action=viewimg&id=69356)
http://www.fquick.com/images/vehicles/full/1079969357.jpg (http://www.fquick.com/garages/viewgallery.php?action=viewimg&id=69357)
http://www.fquick.com/images/vehicles/full/1079974224.jpg (http://www.fquick.com/garages/viewgallery.php?action=viewimg&id=74224)
http://mysite.verizon.net/ccmillers/Enginepagefiles/bay3.jpg
http://mysite.verizon.net/ccmillers/Enginepagefiles/bay2.jpg
http://mysite.verizon.net/ccmillers/intake2.jpg
LawmanSS
10-21-2008, 08:24 PM
Updated listing.
