Need the best FI cam I can get
Hey guys my car is a H/C car I have the TSP PRC LS6 Stage one heads and a 232/234, .595"/.598 cam. I am thinking about adding a D1SC unit to my setup I will change the cam but I only want to do it once and get the best cam I can for the D1. The car does have a stock bottom end that I will keep on the car for a few months then I'll buy a Forged Short Block from TSP to make about 11-14 PSI. For now I will only run 6 psi on the stock bottom end. Whats the best cam I can get? Also are my heads alright for FI?
The heads will be fine, actually the cam you are running now will be fine for a while. At 6psi I dont believe you will see enough gains to do a cam swap just yet. I would wait and do the cam when you get the shortblock and turn up the boost.
Originally Posted by Dustin 98TA
...actually the cam you are running now will be fine for a while. At 6psi I dont believe you will see enough gains to do a cam swap just yet...
