Can I expect about 400hp...?
Old 12-15-2006, 03:02 PM
NoCobra's Avatar
Default Can I expect about 400hp...?
With my setup or about..
ls6 intake
f13 230"/232" .595"/.585" 112LSA
241 castings ported ls1 heads w/ the flow rate of
.100 65/53
.200 135/106
.300 190/145
.400 232/177
.500 263/203
.600 276/219
long tube headers
off road y pipe
magnaflow exhaust
grantelli lid
I still would like to port my TB. On top of all that I want to do a 100shot hopefully by summer.
Old 12-15-2006, 03:31 PM
MillaTK's Avatar
You'd probably get better results in the dyno section, but I'd say you'd be around 400 to the wheels.
Old 12-15-2006, 03:36 PM
NoCobra's Avatar
Can anyone move it to that section?
My whole goal is to break 400 with a good tune.
Old 12-15-2006, 07:45 PM
BayAreaSS's Avatar
I think you will hit right at 400. But that ported Tb will help you out
Old 12-16-2006, 01:45 AM
bjamick's Avatar
I can definitely see you hittin over 400..
Old 12-16-2006, 10:37 AM
Hennytime's Avatar
without a doubt. a buddy of mine hit 390 on a stingy dyno with full exhaust and the cam. no pulley, no ported tb, stock ls6 intake
Old 12-16-2006, 11:06 AM
staringback05's Avatar
depending on the tune you should be pretty close
Old 12-16-2006, 11:14 AM
N4cer's Avatar
385 as a rough guess. Always estimate low so you won't be disappointed.
Old 12-16-2006, 08:40 PM
Keenov's Avatar
I'll give you 405-425rwhp.
Old 12-16-2006, 08:44 PM
2000LS1TA's Avatar
You should be right there
Old 12-16-2006, 09:22 PM
NoCobra's Avatar
I was thinking 380 at the lowest.. but I guess time will only tell.. If he does a agressive tune i should be fine driving it daily, right?
Old 12-17-2006, 05:45 PM
got milk??'s Avatar
i got 380 with everything u have minus the throttle body and through 98 heads safe tune btw
Old 12-17-2006, 11:50 PM
MillaTK's Avatar
If you still want it moved, try PM'ing one of the mods of this section. I don't have that power
Old 12-18-2006, 09:26 AM
'Trust''s Avatar
You better hit 400! I did the numbers in the sig with a smaller cam and through a stalled auto!
Old 12-18-2006, 02:26 PM
jpat1023's Avatar
I can see 410rwhp out of that setup....but don't be disappointed if its 390rwhp.
Old 12-18-2006, 03:08 PM
NoCobra's Avatar
This is depressing.. I want everything installed and tuned.. but I am still waiting for parts to arrive..
Old 12-18-2006, 03:13 PM
lsx24's Avatar
fm13 has been shown to put down itself 400 rwhp, so with mild heads it should be a bit more if M6.
