question for the gods
Old 12-15-2006, 11:36 PM
juiced99z28's Avatar
Default question for the gods
you guys have helped a few times in the past hopefully you can this time. what are the possible causes of my injectors being interrupted ( stop spraying) every 19 seconds?????? @ idle it will die in neutral @ 2k stumbles, @1500 to 2k in gear usually dies unless i goose it. cant remember the exact code now but said it was a security issue and was intterupting signal. thanks guys (and girls).
Old 12-16-2006, 10:07 AM
Vortech GTO's Avatar
Sounds like VATS(Vehicle Anti Theft System) is turning off the injectors try relinking it or turning it off and see if that fixes your problem.
Old 12-16-2006, 01:21 PM
wait4me's Avatar
ARe you sure it is the injectors being cut off? I would check your fuel pressure.
Old 12-17-2006, 07:26 AM
2002_Z28_Six_Speed's Avatar
Pleas to Bacchus get a better result.
