Idle A/F with versa nd 96lb... outcome?
Old 12-16-2006, 02:03 AM
Jammer's Avatar
Default Idle A/F with versa nd 96lb... outcome?
Very few visit the fueling forum, but since most folks with bigger HO are forced induction, I am hoping more people can chime in here than in the fuel section.
I am about to order injectors... I will be runng HP/EFILive (undecided) and am using a VersaFueler ... are people here able to get the idle and transitions in a decent A/F ration area? Would it make the tune /idel easier and perhaps any better with 83's rather than 96's? or not really....
Thanks!
JM
Old 12-16-2006, 10:18 AM
engineermike's Avatar
When I bought my Versafueler, I talked to LJ some on the phone. He said that the idle pw on his 72's was over 1 ms, but with the 96's it's under 1 ms and 1 ms is the lowest duty cycle the ECM can command. So, with the 96's, they will be running at 1 ms and it will still be a little rich. Based on his advice, I chose the 83's and it runs 1.0 - 1.2 ms at idle. Hope this helps.
Mike
Old 12-16-2006, 12:53 PM
Jammer's Avatar
Thats exactly what I wanted to hear...so 83's are the best choice for me.
Old 12-16-2006, 12:57 PM
LSs1Power's Avatar
Who sells the 83's? Is the Versa still needed with them?
Old 12-16-2006, 01:30 PM
Jammer's Avatar
Versa is need for any Low-Imp... There are some High Imps said to be near that level, but I never had luck with anything bigger than the Motoron 60's... I think RC engineering has some decent 75lb'ers, but I'm choosing to go big rather than go home.
Old 12-16-2006, 04:00 PM
NA$TY-TA's Avatar
no problem here commanding 14.7:1 at idle and cruise w/ 96#ers......
Old 12-16-2006, 04:05 PM
LSs1Power's Avatar
Can you give us the secret?
Old 12-16-2006, 05:49 PM
lbz34's Avatar
I can the get a/f numbers to come around but still having drive ability issues and gas mileage is still horrible. The is for sure running rich regardless of a/f numbers but upon leaning it out more it starts to run like it is lean hesitating, stumbling, etc....
I may have some injectors issues i am starting to think. Time will tell i guess.
Old 12-17-2006, 11:47 AM
NA$TY-TA's Avatar
Im using the injector driver box made by harlan and harlan did the idle and WOT tuning via HPtuners and the MAF T Pro.
I have no clue what i would get with overdrive since i dont have it......
3.73's and 1:1 final drive..... i get around 8-12 MPG...... im not worried... i didnt build this for MPG LOOL
Kyle
Old 12-17-2006, 12:05 PM
LSs1Power's Avatar
Once someone needs 96lbs injectors who cares about fuel milage. Im just worried about washing the rings by running rich.
Old 12-17-2006, 01:57 PM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
mines ok if you dont just sit there to long and let it load up on fuel.
Old 12-20-2006, 01:15 AM
Jammer's Avatar
Wow..not too many people with 96lbers (or 83) with a stock PCM and a versafueler????
Old 12-25-2006, 11:57 PM
Jammer's Avatar
ttt c
