no fire when starting!!! I just bought it too.
My 95 z28 has the LT1...runs great but I'm having problems with ignition firing. Recently I've had a battery replacement, excide 630 cca, and was told it wasn't getting fire bc there was not enough cold cranking amps. That was a quick fix now it doing it again, it turns over, all gauges seem normal (to my knowledge), except it will not fire. Fuel pump is working and everything seems to be fine bc I can hear it when I turn the key over....however I do not smell gas really bad any suggestions.
Check this out, a little more info on the lt specific boards
http://mainstreamtopics.com/forums/i...p?showtopic=78
http://web.camaross.com/forums/showt...=injector+volt
