will this work?
Old 12-16-2006, 07:58 PM
blake110106's Avatar
Arrow will this work?
ok im looking into getting a 94 formula firebird with a bad engine(broke rod) and my buddy has an LT1 out of a 94 interceptor caprice. what will i need to change if anything. If i get it im going to go ahead and buy a mild cam and stall converter to save some time of not tearing it all back down again. How much lift will stock spring hold and the limits of an LT1 block? any suggestions on the cam??
Thanks,
Blake
Old 12-31-2006, 08:41 PM
gradez28's Avatar
you should be able to transplant it right over without troubles. I think the caprice might have iron heads but other than that there shouldn't be much physical difference.
I wouldn't bother using the stock springs with any upgraded cam.
Old 12-31-2006, 09:12 PM
95FbFormula's Avatar
Here this should help with some of your questions
http://www.9c1.com/technical/LT1_rebuild/ar99928.htm
Old 12-31-2006, 09:18 PM
the_merv's Avatar
Your Caprice Engine is going to have Iron Heads, and the Vented Opti I believe.
