Is it the tranny or the tires?
How can I tell?
Ok, I was going about 23 mph, then I hit the gas. It immediately downshifted to 1st, but it felt like the RPM's were jumping a little. Once it got into second, it felt like something was slipping. The tires were not making any noise which is why I am concerned. Could be the tires, but I'm wondering if there is a way to confirm. Thanks!
EDIT: No SES light
EDIT: No SES light
Just had it out, I think it was the tires. I did the same thing today, and felt the back-end sliding out as the car accelerated after the downshift (with the windows open I think I also heard the tires slightly). The car also feels normal when I'm driving normal.
The other night it was pretty damp out and moisture was developing on the car, so I think the moisture in the air had some effect on either the tires or the road. Not sure.
Originally Posted by BlackHawk T/A
The car should most definetely have enough power to break the tires loose doing a downshift to 1st, however you should not lose traction by "upshifting".
This is with the stock tires (Eagle GS-C)
yeah, my car does the same thing and i was wondering the same thing. but im sure its just the tires. its like you can feel and hear the car revving up but your going nowhere and hear no tires, just like a grinding sound kind of
Guys I have an FLT Level 4 transmission, with a modified TransGo HD-2 shift kit, big pump and vacuum modulation. Trust me when I say that I am getting plenty of pressure.
What kind of tires are you guys running to spin the tires on upshifts?
After driving the car today, I am more certain that it's the tires. I did not hear the tires screech when accelerating, but did feel the back end slide out a little.
Now, on a newly-paved road, I hit the gas at 20-25 and heard tires screeching immediately after the downshift, and felt a nice crisp 2nd gear shift.
Also checked the tranny fluid and it still looks new (it's about 500 miles old). Bright red-pink color, does not smell burnt.
LS1Tech Administrator
Received 1,489 Likes
As for downshifting, no matter what the outside temp was, they would always break free a bit with a WOT downshift to 1st until the rubber was hot.
My BFG KDWs would react nearly the same as the Nitto DRs, only they didn't get any better as they heated.
