Removing stock exhaust??
Old 12-17-2006, 12:58 PM
houseylou's Avatar
Default Removing stock exhaust??
How hard is it to remove the stock exhaust on an 02' TA? I'm planning on getting a GMMG catback. Here's a couple pics.
Do I just unbolt that whole piece in the first pic.? When I saw it welded I didn't know what to do. For the second piece what needs to happen?
Old 12-17-2006, 01:21 PM
The Trans Am Kid's Avatar
Good luck home boy
Old 12-17-2006, 01:46 PM
jimmypop13's Avatar
Originally Posted by The Trans Am Kid
Good luck home boy
your left tip is lookin a little crooked.
In the first pic, yeah, unbolt it.
in the second, you just pull the metal out of the rubber.
you'll probably have to cut the pipe in half before the axle too, maybe not
Old 12-17-2006, 02:03 PM
Yeah, that was the day after I put my exhaust on. I moved a little but I fixed it since then. I had to cut the pipe going over the rear axle and me and my boys could find anything to cut it with so we used a file. It would have been impossible if we wouldn't have had a lift!
Old 12-17-2006, 02:13 PM
RedWS6 00's Avatar
wont take long before they get all black inside. I tihnk I got the came as toy. 3.5" Corsa catback. They do look the part.
At the beginning of summer I'm gonna clean mine up with a polising bit on the end of a dremel.
Old 12-17-2006, 02:28 PM
I clean the insides of my tips once a week and go back as far as I can. Plus, I work at a carwash so she is always clean.
