Pontiac GTO 2004-2006 - How dangerous IS it...runnin 5X120 wheels...
88MONTESS
12-17-2006, 02:58 PM
I always here people say youcan run 5X120 bolt pattern wheels on your GTO, but that is not the correct pattern... I believe the correct pattern is 5X120.65? There are so many more wheels available in 5X120, but if it is dangerous AT ALL, I'm not goin that route...
tha joker
12-17-2006, 03:51 PM
its the other way around....so 5x120 is our bolt pattern
GoatChs
12-17-2006, 04:09 PM
You have it backward. 5x120mm is the GTO lug pattern; 5x120.65mm (5x4.75") is the GM std lug pattern. Lots of people have run the GM std pattern on the GTO...I was running 120.65 pattern wheels but couldn't get rid of a shimmy in the front end so I got rid of them.
EDIT: Damn you Bobby! :)
88MONTESS
12-17-2006, 04:10 PM
I've also heard that before. Thank you for the feedback. I'll go with the correct lug pattern.
tha joker
12-18-2006, 04:42 AM
:jest: :engarde: :moon: :violin: :chuck-bal :buttkick:
lol colby see ya soon
KrautBurner
12-18-2006, 05:48 AM
most tire shops won't mount F-Body wheels on a gto
they will "fit", but have alot more tendancy to mount misaligned
also the F body hub ring is larger (so It dosn't hold the wheel centered.)
and gto wheels won't fit on the F bodys (hub hole is too small)
