SI3 cam?'s
Originally Posted by Oh4GTO
Dont go duals with that cam. Beehive springs are much better. They dont surge like conventional springs and provide better valve train stability. Comp 918s are good for .600".
Thank you fo your feedback!
918's are fine for your application. when they came out with the dual spring they lowered the lift rate of the 918's to .600 from .625- spring is the same. Just keep an eye on the mileage on the springs and check them every now and then- you should be doing that with aftermarket springs.
as far as pushrods go the 7.4's would be the ones you would need.
