Top Dead Center
Top Dead Center
Well i pulled the hub off at TDC and decided to take some pics before i put the double roller on. Can anyone tell me how to tell if the motor is truly at TDC by looking at the timing chain?
you se that little notch or pin hold at the end of the cam pulley. there should be an equal 1 on the crank sprocket when both are facing each other #6 cylinder is at TDC. by facing i mean crank sprocket pin hole is at 12'o clock and that 1 on the cam is at 6'0clock,
So i would be alright if i put everything back on the exact same way, or do i need rotate till the cam gear dot is at 6 o'clock becuase i dont see a mark on the crank gear.
