Appearance Mods, What would make my car look good?
Well, my car's appearance has been the same now for a while. Although the headlights look good in the pics they are very hazy, and need to be replaced.
GIVE ME YOUR OPINIONS!!!!
The one thing about lowering the car is that I have tsp trueduals. They have lousy ground clearance.
So as of now I'm thinking:
Pewter mirrors
Some sort of grill (opinions wanted!!!)
Clear corners (should I get clear or black housing?)
Headlights (OEM new, Better Whistler, or Halos?)
Pewter mirrors
SLP Grille w/ silver trim, or painted to match the car color
Remove the scoop filler, add a Black Manta
Black Housing headlights
Black Housing corner lights
Stock sidemarkers polished
Red Calipers
Black Berger Panel w/ fill-ins
DragonZ28 SS emblems
Slotted Drilled Rotors
Red Calipers
The only thing I can think of not mentioned is the whistler mod after you get new head lights. There is a sticky at the top that tells how to do the whistler mod, and how to get rid of the hazy lights (save you a lot of money). Would be best to do both at once
I've done the whistler mod on my headlights. I also have tried to clean them up. They didn't turn out too well as far as the haziness goes. The only thing about getting a grill that gets me is being able to see the pewter behind it. Does anyone have any directly front shots of that car above?
maybe some black turn signals would flow good if black is ur accent color with the headlights, definately go with ss grill body colored and maybe the stripe down the middle of the grill should go black... jmo
