just about ready to drop in!
The new 355 awaiting....
Stock crank
Stock block +.30 and .0 decked
Eagle I-beams
ARP rod bolts
ARP Main bolts
SRP forged pistons flat tops -.5cc 11.4:1
SA gear Adj. true double roller chain.
Total seal plasma moly rings
chevitte 77 H series bearings
Fel-pro gaskets
GM847
LE 1.5 heads w/ 918's
matched intake
1.6 RR's
Comp lifters and pushrods
mellings HV pump and ARP pump shaft
Tryin to find a set of LT4 valve covers used but having a hard time Oh well.....hard to work on it this time of year but it will return in early 07'
Stock crank
Eagle I-beams
ARP rod bolts
ARP Main bolts
Fel-pro gaskets
GM847
matched intake
1.6 RR's
