where to get cylinder head coolant plug?
Old 12-20-2006, 01:03 PM
SELLSZ06's Avatar
Default where to get cylinder head coolant plug?
Iam looking for the passenger's side cylinder head coolant plug that goes on the side and back of the head. On the same whole that the coolant sensor plugs into on the front side of the drivers side. You know? Anyway, my dealer said that they only come with the cylinder head purchase.
Old 12-20-2006, 08:07 PM
jetblast's Avatar
Default plug
call jay fischer pontiac, he will help you.
Last edited by Patrick G; 01-02-2008 at 04:33 PM. Reason: Non-sponsor info removed
Old 12-21-2006, 12:50 AM
eallanboggs's Avatar
That's probably a NPT thread. If it is you can just go to your local plumbing supply.
Old 12-21-2006, 06:05 PM
jay_99z's Avatar
This may help
https://ls1tech.com/forums/showthrea...d+coolant+plug
12X1.5 thread
Or Gm Pn 1647542
Old 01-02-2008, 04:25 PM
white99z28's Avatar
The actual part number is gm # 12553191
I hope this helps anybody who needs it.
Evan
Old 01-02-2008, 04:32 PM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
That is correct.
Just tell your moron of a parts counter guy that it miraculously appeared and that it was never available separate form the head before today
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 01-02-2008, 05:41 PM
LS1MCSS's Avatar
Originally Posted by Matt @ SDPC
That is correct.
Old 01-03-2008, 01:16 AM
babydeuce's Avatar
I think I still have the plug I pulled out of mine to install the autometer sensor. If I can find it, you can have it! PM Me
Jack
Old 07-27-2017, 11:48 AM
NC_John's Avatar
Reviving this thread from the grave, the current GM PN for the threaded cylinder head plug, M12x1.5 is 11610259. I had a heck of time finding it so wanted to put it up here in case it helps someone else.
Old 07-27-2017, 08:04 PM
nawlins-tim's Avatar
ictbillet.com
Old 07-28-2017, 06:04 AM
NC_John's Avatar
Originally Posted by nawlins-tim
ictbillet.com
I found that too when i was searching but its nice not having to wait a few days for it to get shipped in.
The parts guy had to call corporate to get and confirm that part number. The head parts/assembly schematic is awful without the needed detail on small parts.
Old 07-28-2017, 08:52 AM
07NBSChevy's Avatar
As mentioned above, the number #229 in this illustration, was part number GM#12553191, which has been replaced by GM#11610259. It can be had at the dealership for around $6.00 and is a normally stock item at every GM Dealership.
Some dealerships used to have, or may still have, a "Block Plug Kit" as well as a "Complete Engine Plug/Accessory Kit", there is a kit #Kxxx, which I can not find at the moment. The Block Plug kit comes with press-in oil galley plug, large brass threaded plug, 3x smaller threaded plugs, and the oil "Barbell". The Complete Engine Plug/Accessory kit includes the previously mentioned plus, the threaded head plug (#229 in illustration), 4x press-in coolant head plugs (#216 in illustration), 4x head alignment dowels, 2x transmission alignment dowels, crankshaft timing chain sprocket woodruff key, 2x rivots for oil pan gasket, and I think the 2x rivets to plug to rear coolant crossover passages. I think that was it, kinda a handy kit. I cant seem to find the part numbers anywhere, I remember buying the complete kit once and was around $80.
Attached Thumbnails where to get cylinder head coolant plug?-051025gm00-272.jpg
Old 07-28-2017, 03:03 PM
00pooterSS's Avatar
If you're in a bind and can't get one quick, run down to the parts store and grab a temp sensor and stick it in there.
Quick Reply: where to get cylinder head coolant plug?
