fast 90mm intake bolts?
Old 12-20-2006, 05:38 PM
Red99TA's Avatar
Default fast 90mm intake bolts?
Just bought one of these used but I read somewhere that it requires different bolts? Is this necessary or will the bolts off my LS6 intake work? If not then where can I pick up a set?
TIA
Old 12-20-2006, 06:01 PM
Red99TA's Avatar
Okay I just answered my own question. Looks like it comes with 10 M8 x 30mm button head cap screws which has a lower installed height than the stockers. Can I get these at a hardware store or do I need to order them from fast?
Old 12-21-2006, 08:30 AM
joelvette's Avatar
the button head screws are for the valley cover which you have to use or you'll crack the bottom of the fast manifold. not sure about the manifold bolts themselves.
Old 12-21-2006, 08:51 AM
lt1formula2000's Avatar
joe is right about the valley cover bolts, I'm in the same spot you are and I just talked to wilson manifolds and they said to contact FAST. Give me a minute and I'll find the number they gave me
here's the number they gave me (FAST) 901-260-3278
Old 12-21-2006, 07:04 PM
jks hugger orange ss's Avatar
You can get the bolts here: http://www.desmoparts.com/screws/screws.htm
They are stainless bolts. You will not be sorry you got them because my intake come with steel bolts, and they rusted in no time. You will need 10 (M6x110mm socket head cap screws, and 10 m6 washers. They are 1.35per bolt, but well worth it. You will not be able to get these at a hard ware store. They are hard to find. Trust me I looked everywhere.
Also they take paypal which makes things a lot easier.
Old 12-21-2006, 08:38 PM
Ls1Envy's Avatar
So do you need the longer TB Bolts?
Old 12-22-2006, 01:03 PM
Red99TA's Avatar
I ended up ordering the FAST hardware kit from thunderracing. It's like $24 IIRC and includes all the nuts/bolts/washers that are supposed to come with the intake. Thanks for the help.
Old 12-23-2006, 09:01 AM
Ls1Envy's Avatar
Well I bought my fast new, so the bolts that came with it will work for my 90mm TB right?
Old 12-23-2006, 09:36 AM
Red99TA's Avatar
According to the FAST website the manifold comes with 5 M6 x 35mm cap screws for the TB.
Quick Reply: fast 90mm intake bolts?
