oil drain into oil pan right underneath timing cover
i know someone on here has this picture, their oil return is in that thin part of the oil pan right underneath the timing cover. im doing it that way so i really need to see that picture!
also will my oil drain freely if i have a straight fitting coming out of it and it goes straight to the turbo up where the battery is??
last question, is it a MYTH that the oil pan can come off with the engine still in the car, i jacked the engine up by the crank pulley and it still didnt look like it gave me enough room
Here is a link to a camaro that has the drain like you want. www.calibercustoms.com
If you put grease all over the drill bit and tap you will have really no metal chips in the pan. The grease collects the shavings. Also the hole will be big enough to look in and get any that do go in. Just take your time and drill slowly.
Yours should drain fine just use no smaller of a line than -10. But there is still no guarantee I will drain enough. If it does not work than run a scavenge pump.
Getting that oil pan off with the engine in the car is a pain, but it can be done. You have to jack up the motor and drop the k-member about an 1-1.5 inches. Do a search on rod bolt installs and you can see how people have managed.
Kevin
Kevin
Hey buddy, that was me. That was a while ago, let me do a bit of digging and find that thread with the pics.
Here is my thread with the pics. Hope that helps.
https://ls1tech.com/forums/showthrea...&highlight=tti
I Bought A New Pan From Gm And I Think Its Smaller In The Front Then My Stock One.i Have A 12an To 3/8npt Straight And It Wont Work On The New Pan But Will On The Stock Pan Still On The Car
