Gears & Axles - 4.30's in 10 bolt are still holding up
miamifan3413
12-21-2006, 12:58 PM
I put 4.30's in my 10 bolt & have drove it pretty damn hard since then (about a month) and am having NO PROBS at all so far.....It feels alot torquer & responsive as hell.....barely a whine at high speeds but am very happy so far:) By the way, thanks Kaliente for the awesome write up, my father & I did the installation & it only took 2 hrs to do.....we didn't experience any complications whatsoever :headbang:
99zman
12-21-2006, 01:16 PM
glad to hear it. go 10bolt go...
h.o.ls1
12-21-2006, 05:50 PM
knock on wood
lt1formula2000
12-22-2006, 11:50 AM
what tires are you running
mzoomora
12-22-2006, 02:59 PM
Are you leaving hard? Hooking well?
~JOSHUA
12-22-2006, 03:33 PM
Just let street tires spin, it'll save the 10-bolt. When you add slicks and hook that's when it's toast.
I abused my 4.11's with a cammed Incon Twin Turbo making 600+ rwhp and my 10 bolt held. :drive: They just spin when you floor it in 4th gear on the interstate. :jest:
miamifan3413
12-24-2006, 01:04 PM
Yes, I'm on trans am chrome's 245/50/16's Fuzion Zri's.....They hook pretty good.....You said it exactly right, add slicks then kiss 10 bolt bye bye :judge:
miamifan3413
12-24-2006, 01:06 PM
I feather the clutch, haven't really tried to launch it hard.....toooo scared too:)
86 IROC
12-24-2006, 01:21 PM
Just curious as to where you found 4.30 gears for the stock 7.625" 10 bolt rear. I usually see the gears jump from 4.10 - 4.56's in the catalogs.
keliente
12-24-2006, 09:04 PM
You know you are asking for trouble by saying your 10 bolt is holding up :jest: Don't jinx yourself!!
Glad my install page could help you out, enjoy!
mzoomora
12-24-2006, 10:10 PM
They came in Isuzu's and mail trucks.
miamifan3413
12-25-2006, 02:23 AM
Exactly right....mine came out of an Isuzu Hombre I believe......only went from 23mpg to 21mpg mixed driving......the car pulls freakin hard, very happy so far:)
miamifan3413
12-25-2006, 02:31 AM
LOL, I know.....living on the edge :eek2: When I was doing the install, the internals look brand new....no wear at all, I was truly amazed how clean everything looked.....matter of fact I used pretty much all the original bolts, pinion bearing & crushsleeve & everything lined up perfectly. I did change my pinion seal while I had it apart but everything was easy as pie :drive: I used a lift which made the install alot easier......maybe I'm lucky with how everything turned out, installing gears was a cinch :)
Brads LS1 02Z
12-26-2006, 02:29 PM
Whenever u do get ur 9" in dont install er right away....get some MT's take to the track and see how high u can get the front tires off the ground!!!!!
just get AAA right before it and cancel it after that month haha
98TADRIVER
12-26-2006, 03:07 PM
heh, you can kiss it goodbye after some good hooking launches on your street tires. i killed my stock 10bolt with 3.42s
haha i used it that night !
watch the vid and listen to the 10bolt going bye bye on my car lol
just bolt ons and street tires
http://thumbs.vidiac.com/82fe6557-b37f-4456-96a9-86bbf7c8924a.jpg (http://videos.streetfire.net/video/82fe6557-b37f-4456-96a9-86bbf7c8924a.htm)Click here to see Video (http://videos.streetfire.net/video/82fe6557-b37f-4456-96a9-86bbf7c8924a.htm)
Revelation Z28
12-26-2006, 03:23 PM
once you pop, you cant stop haha
kevins2000LS1
12-26-2006, 07:10 PM
Can you buy 4.30's new??? anywhere?
86 IROC
12-26-2006, 07:13 PM
Cool, so you bought them used? Or ordered them from a stealership? I have 4.10's now... I want to see where they put me in the lights. 4.30's might put me at a better spot going through the traps. Plus, I'll know what I want inmy 12 bolt when I can afford one. :devil:
miamifan3413
12-26-2006, 10:50 PM
I bought them used for $80.....was gonna get 4.10's, but since the 4.10's are $200 (GM gears) I figured the 4.30's was a no brainer, purchased em on ebay, they looked brand new when I got em:)
miamifan3413
12-26-2006, 10:55 PM
WILL DO!!
Brads LS1 02Z
12-27-2006, 04:44 AM
WILL DO!!
Sweetass haha
and dont forget the camara :drive:
86 IROC
12-27-2006, 07:58 AM
Good deal, thanks man.
