Fueling & Injection - Quick release fuel tank fitting
speedracer5532
12-21-2006, 02:55 PM
I am looking for a quick release fitting that will hook to the factory line at the tank and let me run a -8 AN hose forward. What are my options?
Nasty N8
12-21-2006, 03:52 PM
Russell makes a 3/8" quick connect to -6 male but there is no -8 fitting you need to use an adapter.
Nate
jstacy
12-22-2006, 09:12 AM
Aeromotive has one. 15118 AN-08 to 3/8 Female Quick Connect Adapter
speedracer5532
12-22-2006, 06:59 PM
Aeromotive has one. 15118 AN-08 to 3/8 Female Quick Connect AdapterTrue but the Aeromotive one isn't available until the end of January.
jstacy
12-26-2006, 08:05 AM
Yes it is. Call Summit and have them special order it. They will tell you 4 weeks but I know for a fact that they have 1 15118 and 2 of the 15117.
Old Geezer
12-26-2006, 08:29 AM
?? why use the -8 hose, if the tube feeding it is a -6????
Sorry to bump this up after a few weeks, but I was wondering the same thing. What is the point of running a -8an line if the plastic tube feeding it is 3/8"?
One would think an -8an bulkhead fitting would be the way to go, but it isn't really an option with the plastic sending unit assembly.
Nasty N8
02-13-2007, 01:52 PM
The fitting on the sender is fine with the pressures but it is good to step it up to larger line for the added volume.
Nate
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
