spark table for sts car..
i have a stock internal trans am, and i'm going to be running 5psi. I was wondering if anyone has any tables that they have used or what timings they have used where. obviously part throttle timings can be left alone correct? as it won't be under boost.
and WOT should be around 15 degrees around 4-5krpm?
what about 2krpm to 4krpm?
i would just play with it, as i did while it was N/A to find the timing it seemed to like.... but boost and compression and detonation just don't get along on these stock pistons.....
awesome, thanks for the help. I will surely return the favor for others up here.
also.. with a wideband and the turbo setup.. where should i put it? in the main exhaust stream? or right away from the exhaust side of the turbo?
how about i just post the table
lol. I will add it as an attachment (If FROST doesn't mind) and EVERYONE GIVE THANKS TO FROST(and whoever helped him finding these tables/helping develop these tables) for the help on a decent boost spark table.
I'm not going to be posting this table, as certain people do not want me to post it. if you know about detonation and knock retard then you know on a stock internal LS1... run about 12-14 degrees WOT and go from there. I hate to say that I'm not going to post it but I'm not, don't mean to make anyone angry either. If anyone wants help feel free to PM Frost or me and ask and we will help. People made me learn and I'm apparently doing a decent job at it. Also remember you will/may not make peak power at close to detonation or KR.. a few degrees less will do fine. Use your SCANTOOL to your advantage.
and like I said, I will be glad to help anyone who PM's me, I always have as I'm sure others also do.
ouch...i bet that had to hurt.
oh, and where should i place the wideband? in the normal rear 02 whole? or on the exhaust of the turbo ( way inside tailpipe?)
FWIW I recently spent time on the dyno and my street tune with no KR was quite a few degrees away from optimal. And it was TOO ADVANCED, meaning I had to retard spark for best torque, not advance it.
You really cant tune spark on the street other than avoiding KR. If you want max power you will need to visit a steady state dyno.
Thanks.
i know about the steady state dyno's ; but where in the hell are there ones around the North Carolina area? lol. I assume that you are talking about the Eddie current dyno, where you can hold it at a given rpm and full load on the car but you can choose the rpm to run at?
Yep, ring around someone should have one somewhere
My sparkmap is NA app with 11:1 and Dart heads so likely not relevant... plus its a work in progress. Ill post it up when its done. Got to book another visit in once I fit the fast90/90
