Eastern Members - SD tune and NY inspection
Jammer
12-22-2006, 10:53 PM
Anyone with an SD tune able to pass NY inspection???
Thanks. JM
Nasty350LT1
12-23-2006, 04:52 AM
Details, we need more Details.
Jammer
12-26-2006, 12:06 AM
bueller? anyone?
studderin
12-26-2006, 01:13 AM
http://www.neweraperformanceparts.com/
I know the turbo shop camaro is SD
BlackScreaminMachine
12-26-2006, 06:38 AM
Thanks. JM
Yea it all depends, what year car, what type of emissions.
In CT if your factory ODB1, you go on the roller, if your 1996+ ODB2 you get scanned. In CT its easier to pass on the scan. But again what do you have???
Jammer
12-28-2006, 11:36 PM
99 TT Trans Am... SD w/ EFI live is the plan.
JL ws-6
12-29-2006, 05:07 AM
I'd be intrested to hear if you can make it thru the OBD2 scan with a SD setup..
Obviously you're not getting the car thru a sniffer, I assume NY is a obd2 scan test?
Mssingkid
12-29-2006, 05:37 PM
Yes NY Is OBD II. :)
JL ws-6
12-29-2006, 05:46 PM
Intresting. I'll be intrested to hear the results of getting the SD car thru, if it can be done, I might have something in my intake tract that may take a permanent vacation.
Redline-Motorsports
01-01-2007, 01:20 AM
I do them all the time with no problems. DOT only looks for either open MIL lights and/or failed tests. When you run SD you force the MAF to fail which trips a MIL light for the MAF. Disabling the MIL enablers for those codes will stop it from being a problem. There are a few other enablers that need to be snuffed to complete the clean bill of health!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
