(EFI Live) Questions on auto VE and the black box feature.
I want to use the auto VE procedure using the black box feature. Is it Ok to use a scan Frame delay of 200ms to increase my black box scan time to 48 minutes while doing the auto VE procedure? Is there any adverse effects using the black box with auto VE? Or would It be better to use the laptop?
It would be better to have the frame rate at 10fps. You could log less PIDs which will also increase the log time. Also remember to change the number of frames where it auto stops logging to 0 or you may get cut short anyway.
Laptop or blackbox is indifferent provided you can get the number of PIDs you need and for the required time period. I generally use laptop all the time, but thats just me.
