6.2L L92 in LSx GTO?
Old 12-24-2006, 01:49 AM
stone4779's Avatar
Default 6.2L L92 in LSx GTO?
I just bought an LS1 GTO and was wondering if we could utilize the cam phaser used for the VVT in the 6.2L in the new Escalade??
The block is 4.060"....0.060 larger than an LS2, and listed for $1300ish a GMPP
Can you just upgrade the O.S. using HPTuners or it doesnt work that way?
I really appreciate any help...I am seriously thinking about taking this extra LS1 I have apart and use the insides to build an L92 and see what kind of numbers it could put down.
Also, does anyone know how this VVT works? does it advance the cam at lower rpms then retard as rpms climb? or does it constantly change depending less on RPM and more on engine load or throttle position, etc?
There is still only one cam lobe for each valve so I know it doesnt work like VTEC, changing lobes after a specific RPM...
Old 12-30-2006, 11:58 AM
stone4779's Avatar
ttt fellas.....
sooo anyone know if the cam phaser can be used on previous gen IIIs and IVs?
Old 12-31-2006, 01:08 AM
98RedZone's Avatar
Try asking in the internal engine section. Interesting question.
Old 12-31-2006, 01:11 AM
gametech's Avatar
Or try the conversions and hybrids section. There is a lot of info there on unusual situations.
Old 12-31-2006, 03:00 PM
stone4779's Avatar
Good idea.. I'm going to double post it over in Hybrids...I didnt even think of that, doh!
