Idleing @ 18-19 AFR is this Right?
Old 12-24-2006, 02:28 PM
Pro Mouse's Avatar
Question Idleing @ 18-19 AFR is this Right?
I just got my wide Band Hooked up.What AFR Should be at Idle?I have a 408 with a 244/248 Cam.I am Idling Between 18.5 and 19.0 is this Right? Thanks
Old 12-24-2006, 05:05 PM
black_z's Avatar
Did you calibrate the wideband? You should idle around stochiometric (14.5:1-15:1)
Old 12-24-2006, 05:43 PM
Pro Mouse's Avatar
Yes I did it per the directions 2 times just to make sure and both times were the same.I thought 14-15ish was right.My Tune is an openloop tune.Should I dial it in with the OLFA Table?Thanks
Old 12-24-2006, 05:53 PM
engineermike's Avatar
If the WBO2 sensor is too close to the end of the exhaust pipe, then it will show very lean until you put a load on the engine. This is due to reversion of air into the exhaust pipe.
Mike
Old 12-24-2006, 07:15 PM
dmoss69's Avatar
Default cam overlap
Another thing also,
If you have cam overlaping, you'll get a lean idle reading with the wideband O2! It's reading the oxygen escaping the combustion chamber during the overlap.
Thing is, if it will idle smooth on 18.5 to 19 afr, and your off idle transaction is smooth, then I'd save the gas and let her ride.
Now cruising around, I'd richen it up to 14.5 to 16 afr. Accleration, I'd defintely richen her up to around 12.5, flatlining WOT around 12.9 to 13.2.
That's just saving gas at cruise and idle.
D Moss
Old 12-24-2006, 10:39 PM
Pro Mouse's Avatar
I did gas it a little by hand and it did come up to 14-16 not hitting gas hard though.Idle is good and doesnt do any stumbling on excel or decel.Reving engine up in Nuetrol she comes back to Idle fine.Idling like this ,Can it cause an extreme smell of Fuel?Damn I mean it makes my eyes burn....
Old 12-25-2006, 08:47 AM
black_z's Avatar
What are the AFR's when you cruise around? Is there an exhaust leak anywhere before the WB02?
Old 12-26-2006, 09:41 AM
Pro Mouse's Avatar
I dont know what it is cruising around yet.I wont know that until spring.This problem is what made me put it away for winter in the firstplace.The damn thing floods out from trying to start it from 50 degrees and lower and will not start.
Old 12-26-2006, 12:33 PM
12secSS's Avatar
Did you disable the air pump, this is most always the culprit. Try turning it off with the VCM controls and see what happens.
Old 12-26-2006, 03:11 PM
Restricted User
98Z28CobraKiller's Avatar
Also, is this happening from a cold start up to 180 ish or is it happening after the car has been run and then restarted? If the later, it could be a heatsoaked IAT sensor. It is a known condition and should richen up after the IAT cools back down to the actual Intake air temp. I put a resistor in my IAT sensor plug that reads 64* all the time. No more problem. Now I live in Florida and my intake air temp is usually within 30* from summer to winter. Good luck.
Old 12-26-2006, 03:25 PM
Pro Mouse's Avatar
all the time cold and Hot start ,I will try to disable the pump but I believe it already is
Old 12-26-2006, 08:34 PM
Restricted User
Is the VE table dialed in? If not, you have to add to the VE table values in the idle area. Are you logging AFR thru HPT? If you are not because you dont have the IO (Pro version) there are a few good write ups on how to log thru the EGR and a couple of other sensors. Do a search. I am logging mine thru the EGR and it made tuning soooooo much easier.
